Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Error code E20 on Zanussi ZWD 1471S
- This topic has 8 replies, 4 voices, and was last updated 16 years, 4 months ago by
BEATS.
December 9, 2009 at 12:26 pm #50795
BEATS
ParticipantHaving an error code when drying clothes (E20 )MODEL IS A Zanussi ZWD 1471S which according to the manual is a problem with the water draining. During normal wash sequence the washer works perfect it is only when the dryer is used that this error comes up. Tried looking at filters etc but looks ok.
December 9, 2009 at 12:49 pm #306016bazza500
ParticipantRe: Error code E20 on Zanussi ZWD 1471S
Hello again,
If you are only getting this on the drying cycle then the first thing to do is insulation test the element and check that the dryer condenser is not clogged.Power off first please…
December 9, 2009 at 11:10 pm #306017helo_75
Participantnah , just change the pump, for sure itll be cutting out after overheating on the dry cycle
December 10, 2009 at 1:07 am #306018Penguin45
True, but good practice would be to split the casing and clean the condenser housing anyway.
December 11, 2009 at 12:45 pm #306019BEATS
ParticipantHi Bazza looks like my household likes these element faults, Is this an easy task to get the element tested, or if the dryer condenser is blocked is this an easy thing to spot and dismantle as unlike my cooker fault I have never stripped down a washer/dryer.
December 11, 2009 at 9:08 pm #306020bazza500
The element would be easier tested in situ(sits inside metal trunking across top of machine). Cleaning the condenser requires splitting the cabinet and removing the back half. 1 screw either side at bottom centre of appliance behind plastic cover, 3 screws at back corners(bottom 2 at drainhose side) and 2 at top in middle which you will see after lid removed. Condenser is plastic part that sits below dryer fan motor.
Power off if trying this youself please!
December 14, 2009 at 6:20 pm #306021BEATS
ParticipantThanks will try the condenser as I do not have a meter to test and is probably the easier option.
December 22, 2009 at 4:05 pm #306022BEATS
ParticipantHi guys thanks for the advice the condenser was chock-a-block with damp fluff have not tried it as of yet but hopefully that was the prob.
December 23, 2009 at 7:17 pm #306023BEATS
ParticipantThat was the problem drying like a good un again with no error message cheers and a merry christmas.
