Mike,
F10 is to do with the water level switch. Possibly chamber blocked, switch failure or digi-board. As you see, a few possibilities!
If you are not sure of you abilities, check the Directories section for an UKW engineer in your area, or pop up your postcode and someone will pick up on it.
If you wish to investigate further, pull the plug first. :plug:
