Error codes 4 and 5 – HOTPOINT DWF50P
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Error codes 4 and 5 – HOTPOINT DWF50P
  • #20534
    pn
    The Hotpoint manual states that flashing lights 4 and 5 mean that water is not connected – but my water connection is functioning ok. There is a buzzing from the right side of the machine (bottom) – sounds to me as though a microswitch sensor or pump has gone on the blink.
    Any ideas/suggestions welcomed. P.S. Like the look of the site!
    #187384
    Re: Error codes 4 and 5 – HOTPOINT DWF50P
    4+5 is timeout on fill. Humming noise most likely solenoid on fill valve, so kinked hose behind machine distinct possibility, assuming, as you say, that the water is on.
    pn
    Penguin45 wrote:4+5 is timeout on fill. Humming noise most likely solenoid on fill valve, so kinked hose behind machine distinct possibility, assuming, as you say, that the water is on.
    Hi Penguin – thank you for the quick reply.
    Going to check out your suggestion (not tonight though as I’ve an urgent glass of scotch to check out)
    Cheers and thanks again!
