Hoover vented VHV 680C.
It works for a few minutes with a loud noise, then stops and all lights flashing. I can’t determine the fault code as it continues flashing indefinitely. If I turn it off and start again it will repeat the process. What next please.
😀 Hi Dave, spot on…the fan is melted. What would cause that to happen so we can avoid this again?
Thank you so much for taking the time to share your knowledge, appreciated. Galwaygirl
