Error codes, FP 501 smartdrive
Home Forums Public Support Forums International Forums Australasian Appliance Forum Error codes, FP 501 smartdrive
  • #18818
    fairfield
    I followed various advice & got a code of 0001011. from my Fisher Paykel 501. Anyone able to translate that, please?
    #180518
    Re: Error codes, FP 501 smartdrive
    Problem with the water level control. With the machine completely drained of water, check air hose for kinks, trapping, holes or water in the tube. Remove hose at control panel end and blow through to check for restrictions, replace and test.
    Power off when working please.
    fairfield
    Thanks for that, it matches the symptoms, but I had already done all the checks on level, including stripping & re-soldering the area around the pressure sensor! Looks like the main board – dammit.
    #180520
    You have mail……
