Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Error E4 on Necht Dishwasher
- This topic has 8 replies, 7 voices, and was last updated 20 years, 5 months ago by
Rachael.
November 2, 2005 at 5:06 pm #12993
Rachael
ParticipantHi
Was wondering if you can shed any light on an error I have on my Necht Dishwasher, it keeps beping at me with E4 on the display, I have tried unplugging etc to see if it clears it but it doesnt, I can not select any programme etc.
This is now the third dishwasher I have had from Necht(the other two were faulty and they replaced FOC) and I can not get through to them, suprise suprise….WQP12 9319
Many Thanks In Advance
Yours
Rachael
November 2, 2005 at 5:48 pm #152563Dave_Conway
ParticipantRe: Error E4 on Necht Dushwasher
This is a Haier made dishwasher rebranded.
Unfortunately there is little to no service information on these I’m afraid 🙁
Keep trying Necht (Maple Industries).
November 2, 2005 at 6:08 pm #152564NWAR
ModeratorRe: Error E4 on Necht Dushwasher
E4 on these piles of poo is supposed to mean that the temperature sensor has failed. Either the thermostat has popped or there is a wire not properly connected.
Some (not all) have a reset stat which may have tripped.
If you can see an ‘L’ shaped element inside the dishwasher then it’s probably the stat that’s tripped.
If you can’t see this element then you’ll have a heater chamber with embedded stats. Changing this is not a DIY job and will require a professional to change (try Repairs@ for someone local).👿 Haier :haier:
If you decide to take a look yourself then please pull the plug first :plug:
Craig
November 2, 2005 at 11:45 pm #152565Rachael
It has the L shaped element as you described, so what should I look for now. The main prob I have is its an integrated appliance, so for me to start lugging it around may be more trouble than it is worth. However if it is a quick solution I am more than happy to have ago. I will in the meantime keep trying Maple!!!!!! No holding of breath from this side though, mind you they have been very good and replaced x 2 without question, would have been nice to be replaced with a model without faults though!!!
R
November 2, 2005 at 11:55 pm #152566iadom
Just type ‘Vance Miller’ into Google and you will find out all you need to know about Maple Industries kitchens. 😥
November 3, 2005 at 12:06 am #152567Penguin45
You say that this is your third dishwasher? Assuming that the guarantee is still valid it has to be time for a refund or replacement with a superior product. Do not settle for anything less.
The problems with these machines are extensively documented – they are made to a price, so quality is an issue; spares are coming from China, so supply is an issue; service is through a network, so that’s an issue… Do I have to go on?
Neff and Smeg do an extensive range of integrated dishwashers of far superior quality, I’d go there.
Penguin45.November 7, 2005 at 1:18 pm #152568samsuki
I have exactly the same fault with my dishwasher, which I’ve only used three times. Necht seem to be rebranded Haier dishwashers – their customer support number is 0870 909 9100. They couldn’t help me as I don’t have my model number with me, but they at least tried!
November 19, 2005 at 11:19 am #152569Rachael
I have been lucky and managed to get hold of them and an engineer is coming out to me next week.
I’ll post a result when I have one!!December 9, 2006 at 8:26 pm #152570richrolo
I have the same problem iwth mine. I have Googled this subject and with a combination of all the advice I have found, I did the following:
Tilted the dishwsher slightly backwards. The dishwasher now works again. Basically the float switch needed a bit of encouraging to reset.
I have also decided to use the dishwasher specific salt granules and not rely on the 3 in 1 for keep it going.
Thanks for the suggestions.
