Error with MW051-U
  • #24064
    chrisduryea1979
    Hi hope someone can help.
    I live in Brisbane Aus. I have a F&P MW051-U
    I have checked the forum and did the diagnostics and came up with the following code.
    0 0 1 0 1 0 1 1
    Long Short Rinse Final Spin
    Wash Wash Rinse
    I appears as though the drive trying to turn the drum but only turns all little each time.
    Thanks in advance
    Chris Duryea
    Brisbane, Qld Australia
    #200517
    Re: Error with MW051-U
    The good old Out of Balance problem…….
    1) Check bias spring is attatched to tub.
    2) Check suspension is correctly attatched and free to move.
    3) Check function of switch – it should be free to move easily and not be stiff, corroded or wet. Wiring can also deteriorate.
    You’ll need to take the top deck off to check fully – two screws at the back.
    somotec
    Penguin45 wrote:The good old Out of Balance problem…….
    I’ve had the same but it goes away – looks like I’ll have to do some maint.
    I’ve see reference to different “phases” of F&P washers how do I know what mine is ?
    Can I get a list of all the codes for this machine.
    thanks john
    #200519
    If yours is an 051, it’s a phase 2.
    No, I can’t publish the codes. F+P don’t mind if we answer your specific questions, but will get somewhat peeved if I put up all their copyright tech info. Sorry.
    Check your OOB switch for corrosion and dodgy wiring – it’s a regular thing.
