esl4126 door leak Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › esl4126 door leak This topic has 3 replies, 2 voices, and was last updated 16 years, 7 months ago by dopper. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts September 10, 2009 at 9:15 am #48486 dopperParticipant got a elux esl4126 dishwasher and its leaking from the door. have replaced both door seals but it still leaks.took the door cover of and you can see the water splashing up under the door. why with the new seals on? dop September 10, 2009 at 10:09 am #296715 mbdasParticipant Re: esl4126 door leak Hi 🙂 I’ve had one doing the same and it was that the lower spray arm was split and blasting water under the seal but not the same model 🙂 mark September 12, 2009 at 8:32 am #296716 dopperParticipant Re: esl4126 door leak will cheak it but had a new arm fitted as it was blocked but was leak b4 new arm fitted as well? cheers anyway September 12, 2009 at 1:11 pm #296717 dopperParticipant Re: esl4126 door leak looks like there is a split in that arm ewill order a one in Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
