Eurokera cook top – HELP
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Eurokera cook top – HELP
  • #61230
    yvvas
    Hi guys,
    I ropped a pot on my cooktop and accidentally cracked it. I need to replace it, does anyone know where I can purchase a @eurokera@ ceramic cook top?
    My oven says caple on it but the stove top is eurokera.
    Any advice will be greatly appreciated!
    Thanks!
    #345366
    Re: Eurokera cook top – HELP
    Is it a separate hob, are there any model numbers on the underside of the hob?
    Most ceramic glass hob tops will cost you virtually as much as a new unit.
    #345367
    yvvas
    the glass itself is craced over one of the burners..i cant see the underside of the hob, its still connected
    #345368
    Without a model number it is unlikely anyone can help. Do you have an instruction book for it?
    It looks as though eurokera is the manufacturer of the ceramic glass, not the actual hob.
    You will need a make and model number to get anywhere I’m afraid.
    I will ask again, is this a separate hob or is it a complete oven?
    #345369
    yvvas
    the oven is below the electric hob is on the countertop..is that what you mean?
    the oven says caple on it
    #345370
    The simple fact is that without any make or model number we cannot help. 😥
    #345371
    yvvas wrote:the oven says caple on it
    Then it’s likely the ceramic hob is also Caple? Take a look at their web site to see if you can identify it, might just be the way forward?:wink:
    CLICK HERE and check it out! 😀
