Eurolec DW004
Viewing 8 posts - 16 through 23 (of 23 total)
  • #120006
    nessy
    Re: Eurolec DW004
    Thanks for your speedy response kwatt.
    I don’t much like the price though..! I’ll try the manufacture’s sense of duty as the machine is only one month out of warranty…
    Wish me luck, otherwise I’ll get back to you regarding for some advice re a DW with a little better quality in the build.
    Thanks Again
    P.s
    What sort of card is this please? would it be fixable. I have been used to pcb repair to component level, but of course information is required about the board to start with…I suspect that may not be available.
    Paul
    #120007
    nessy
    Re: Eurolec DW004
    An update Guys, Manufacturer agent has agreed to fix the Dw under warranty and that should happen on Friday.
    Thanks everyone who found the time to reply to me on this forum
    Cheers
    Paul
    #120008
    nessy
    Re: Eurolec DW004
    Hi, Well no one turned up to fix the DW,didn’t even have the courtesy to call to say they wouldn’t be arriving…waited in all day.Am I just being picky, or is this service standard acceptable?
    #120009
    Re: Eurolec DW004
    Hi Nessy,
    No it’s not acceptable at all. If you’re not going to make a call the least you can do is inform the customer as soon as is humanly possible, sadly that often isn’t until you actualy realise or are told that there is a problem. 😕
    Eurolec service is dealt with by agents for Anglo Iberian Services mainly to my knowledge and you can get them on 01245-320992. If you call and ask if the call was logged through them they should be able to provide you with the number of your local repairer. If you get any real hassles ask to speak to Terry Ellis who should be able to resolve it for you, if they have the call of course.
    Hope that helps a bit.
    nessy
    Re: Eurolec DW004
    Thanks again, I’ll follow this up.
    Cheers!
    #120011
    nessy
    Re: Eurolec DW004
    Hi KWatt…
    The saga continues. Can you give me an idea of price for the membrane keypad for this DW please? It looks as if that’s flakey too…! 😕
    #120012
    From memory Nessy they’re about £20-30. 😕
    Re: Eurolec
    eurolec service is 01245 321111
