Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Eurolec DW004
- This topic has 22 replies, 5 voices, and was last updated 21 years, 4 months ago by
nessy.
November 20, 2004 at 6:30 pm #6868
nessy
ParticipantHi,
Hi, our dishwasher a Eurolec DW004, first started to make random bleeping noise. Then it would not respond to any prog button. After many trys, a prog was selected and ran o.k. Now the machine does not respond to any button on the control pad, but all of the leds are on. Power down and back on had no effect. Help please, or I may have to do the washing up myself!
Paul 😳November 20, 2004 at 7:29 pm #119992Dave_Conway
ParticipantRe: Eurolec DW004
I can’t think who actually makes Eurolec dishwashers, as they will be a rebadged appliance from one of the “better known” names.
Are there any other numbers you can let me have from the rating plate which should be around the door somewhere.
In the meantime….
November 20, 2004 at 8:23 pm #119993nessy
Thanks Dave …I love a sense of humour
Details from door:
Essentials Range. Dw004
Ser No: 030608757
Type: DW 24E1
COD; 90647 1589
NIF ESF 2002 0517
Thanks,I look forward to putting the fairy back into the cupbord !
PaulNovember 20, 2004 at 8:36 pm #119994Dave_Conway
Keep it out ’till Monday when I’m back at work and have the technical info to hand.
I’ll check it out then for you 🙂
November 20, 2004 at 8:52 pm #119995nessy
Thanks, I’ll start a pending file for the dirty plates….
November 20, 2004 at 9:48 pm #119996kwatt
KeymasterEurolec is a brand name handled by AIS and all I’ve seen are Fagor in sunglasses and they have a predoliction for blowing the main board. 🙁
On the upside the PCB isn’t that badly priced.
November 20, 2004 at 10:28 pm #119997Dave_Conway
OK thanks Ken.
I’ll contact AIS on Monday for nessy then.
November 21, 2004 at 10:03 am #119998admin
KeymasterRe: Eurolec DW004
eurolec is the brand name for waterline,crusina,its basicly a fagor vfu651 and it will be the pcb at fault.
bryan
November 21, 2004 at 12:34 pm #119999nessy
Thanks Bryan & co . All I have to do now then is buy the pcb and decide how to get the covers off….any ideas will be appreciated.
I ‘ve been in tech support for donkey’s, but have never had the pleasure of a dishwasher….
PaulNovember 21, 2004 at 7:08 pm #120000admin
sorry,
are you an engineer?
bryan
November 21, 2004 at 7:26 pm #120001Penguin45
ParticipantNessy,
Bear in mind that the comments made so far are based on the experience of the engineers who put their time into the site. None of us has actually seen the appliance, so while we SUGGEST that the computer is at fault, there is no guarantee that this is so.The board WILL be an expensive component, and will not be returnable to the supplier under any circumstances, so if we have an incorrect diagnosis, you could be making an expensive mistake.
Short of obvious dry joints and the like, the board cannot be tested, so an appliance engineer attending would basically have to test every component and circuit around the appliance. If it ALL checks out, the only candidate left will be the computer board.
Unless you feel confident to do this, you are guessing and it could be expensive! My advice if this is not the case is to pop your postcode up and see if there is a local UKW engineer in your area.
Whatever you do, pull the plug first.
Penguin45.November 21, 2004 at 8:20 pm #120002nessy
Thanks Penguin,
I do feel o.k around industrial stuff,logic, embeded microprocessors and the like,indeed this was all I did to pay the mortgage until a couple of years ago. I’ve never had the motivation to look at a dishwasher before but have always managed to fix the washing machine.
I’m surprised how difficult it’s proving to find out information for this offending machine and do appreciate you efforts to help.
Do you have an idea how expensive is the card for the dw004 please,or where may be the best place to source it? I have been lokking on the net,but perhaps not in the correct place!
Should I cut the losses and junk the dishwasher do you think?
PaulNovember 21, 2004 at 9:07 pm #120003nessy
Yes Bryan, but not in the domestic appliance field. Service manager for an international company in the printing industry until a couple of years ago.
November 21, 2004 at 9:14 pm #120004Penguin45
ParticipantHang fire ’til Monday, Dave will probably be able to either source it or point you in the right direction.
Penguin45.November 22, 2004 at 12:24 pm #120005kwatt
KeymasterV54E000F4 – PCB/Programmer – £79.00 excl VAT & Carriage. Bear in mind most of the DW PCB’s are easily £100+ + + 😕
Nil stock at present, more due soon.
Didn’t have to dig back through many invoices to get that information. 😉
