Well her it goes…
American type fridge/freezer samsung Model:RDH1DKRS
Have three kids in the house opening the fridge and evnatuly the evaparator froze up causing the fan blade to freeze stuck.
This was then left like this for too long causing the motor at least to burn… this I know …
Now for the more scratch my head problem, i changed the motor and started the fridge again and got an alarm indicator on the panel(looked it up: fault on fan wire lose broken ect).
Then proseeded to check the line from motor to main board and no problem there signal al the way,but when starting the fridge the voltage between power in and ground is mV (should be between 7-12V)!!!
The strange thing is when i connect the old motor back in place the alarm is not active but the motor is burned and have O.L ohms so why is the fridge “accepting” the broken motor but not the new one?
Change Main board burned relay?
