EWG14250W LOCK OUT OF PROGRAMME
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries EWG14250W LOCK OUT OF PROGRAMME
  • #92424
    alro
    Hi gents pnc 914528210/02 wont start can select programme press start and flashes green as tho its on pause does anyone know the way to go into a test programme or so i can diagnois ihe fault as no error code was on the machine just stop full of water cheers alro
    #451253
    Seamy
    Re: EWG14250W LOCK OUT OF PROGRAMME
    If its full of water, perhaps check pump first, maybe if you resolve that problem it’ll go through program’, thinking it should be empty at start or maybe looking for water level going down at least. Also check door lock, that its actually locked door, try open after start pressed, if door opens maybe problem with interlock, wiring to it etc…
    #451254
    alro
    drained water out by filter before i got there by customer still no start and door open wont lock start button flashing when pressed that why i need away to the diagnostics to enter programme for error code thanks for reply anyway cheers alro
    #451255
