Recently I have needed to replenish the rinse aid much more frequently than before, at least once a week. The light indicates that it is empty, and judging from the ammount to fill that is indeed so. Any suggestions?
TIA
Certainly it would involve closer inspection of the dispenser unit and most likely the rinse aid plunger/valve is probably not seating properly. It can be repaired/replaced as all the component parts are available seperately. However I would always recommend changing the Dispenser Assembly (Part No: 1801684) though they are not cheap at around £60 ish
