External oven temp on single oven
Home Forums General Trade Forum External oven temp on single oven
  • #103338
    funbobby
    Went to a single whirlpool oven and when I pulled it out after running it at 200 for a bit the bottom of the oven was roasting hot. Insulation seemed fine and it’s only 3 years old. Is this normal on the cheaper stuff? Worried it could scorch the cupboard
    #492764
    funbobby
    Just to add I had been running it using the bottom element
    #492765
    You’d have to measure the temps to be sure but what they ought to be and where to measure is explained here:
    https://www.ukwhitegoods.co.uk/help/fix-it-yourself/ovens-hobs-a-cookers/3523-temperature-testing-a-built-in-oven
    funbobby
    What would be the acceptable at the bottom though? I can’t see anything on there for that area?
    #492767
    This was what I was looking for, it’s the BSI standards that still apply:
    https://www.ukwhitegoods.co.uk/help/buying-advice/cooking-products/2640-bsi-oven-temperatures
    Basically, they can get bloody hot! Something in the order of 80˚C-100˚C would not be out of the question.
    funbobby
    Yes this was bloody hot , couldn’t touch base for more than a second or so. Obviously the bottom element is right there so I expect it to be hot but this seemed excessive?
    #492769
    funbobby
    The underside that is, not the cavity obviously
    #492770
    funbobby
    Interesting to read , so a kitchen cabinet is normally heat resistant to 100c , you learn something new everyday 🙂
    #492771
    Yep and a lot of them aren’t sadly.
    Hollytree_Technical
    Might also be worth double checking the installation instructions as there are some that are meant to be mounted on brackets without a cabinet base.
    Jem
