Extra long drain and inlet pipe
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Extra long drain and inlet pipe
  • #86283
    slatey
    Hi,I have just bought a Kenwood KDW60W15 dishwasher and need an inlet and outlet pipe approx 6 mtrs do those lengths exist or do i have to connect a couple together? Any help or advice is most welcome.
    #430713
    Re: Extra long drain and inlet pipe
    There are no hoses of that length and although the fill hose of that length will not be a problem the machine is not designed to pump water out over that distance, even a decent quality machine would not work correctly and a budget, possibly Chinese made one will certainly struggle.
    #430714
    slatey
    iadom wrote:There are no hoses of that length and although the fill hose of that length will not be a problem the machine is not designed to pump water out over that distance, even a decent quality machine would not work correctly and a budget, possibly Chinese made one will certainly struggle.
    Ok maybe i should just give it a drain of its own?
    #430715
    The only sensible solution TBH.
