Extractor Decorative Trim Removal
Home Forums Public Support Forums Help And Support Other Appliances Extractor Decorative Trim Removal
  • #102396
    phil3012
    There is an issue with the lights on my Lamona Curved Glass Chimney Extractor and I had an engineer visit.
    He wasn’t able to remove the decorative chimney surround and suggested I need a joiner to remove the kitchen panels above, which I’m not keen on.
    The surround catches on the raised bit as shown in the photo and would also likely catch on the control panel.
    Any ideas how I can remove the surround please?
    #488627
    if the surround is cut into the wood at the top you will have to remove the wood panels first
    kitchen fitter are a nightmare, dont think things ever need to come out again, see this lots
    phil3012
    electrofix wrote:if the surround is cut into the wood at the top you will have to remove the wood panels first
    It’s not cut into the overhead panel just rests on it both at the top and bottom.
    #488629
    ok
    take out filters underneath and look to see it there are any mounting screws into the wall
    if yes undo a few turns (don’t remove them), what am hoping is you may get a little movement to allow you to withdraw the cover
    phil3012
    Still no joy, I can’t actually see how it was fitted in the first place. Think I’m just going to have to live with having no lights on the cooker hood 🙁
    #488631
    you will find the wood will be screwed to the top of the kitchen units. find the screws and release the front ones and loosen the back ones. you should then be able to spring it enough to get it out. you might have to insert temp wedges to hold it up but you only need 5mm or so to get it out
