F 05 Error code on Hotpoint WD640
Home Forums Public Support Forums Help And Support Washing Machine Help Forum F 05 Error code on Hotpoint WD640
  • #8931
    I have searched for error codes on Hotpoint, but cannot find the meaning of error F-05…
    Any ideas? This is a WD640G model and is only a couple of months old…and I am about to chuck the old washer away.
    Any help would be appreciated.
    Stuart
    #131180
    Re: F 05 Error code on Hotpoint WD640
    As it is under guarantee you need to contact Hotpoint direct on 0870 9 066 066 first and foremost.
    The fault is associated with drain out (pump blocked or restricted in some way) I expect you’ve been trying to wash something that has given off a lot of fluff and or/debris???
    Thanks for the reply…
    I’ll contact them tomorrow…
    Not quite sure what was being washed as the misus was doing it. Will have a look at the outlet to make sure it’s okay.
    Stuart
    #131182
    richard31
    As yours is under warranty, call out a service guy. Just had the same fault on our machine. If your missus has long hair and malts like a hound, you will probably find the inlet to the drain pump is so clogged up with matted hair and lint that the impeller won’t turn, really easy to fix toook me 45 minutes. Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned. Our machine works well, for now, but it’s a Hotpoint so I,ll keep in touch and let you know what goes wrong next week!! PS Don’t buy another hotpoint, we won’t.
    #131183
    Date?????
    #131184
    mij
    an f05 error message means that the pressure switch is jammed on empty or as already said a problem with pump
    #131185
    stephen1966
    richard31 wrote:As yours is under warranty, call out a service guy. Just had the same fault on our machine. If your missus has long hair and malts like a hound, you will probably find the inlet to the drain pump is so clogged up with matted hair and lint that the impeller won’t turn, really easy to fix toook me 45 minutes. Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned. Our machine works well, for now, but it’s a Hotpoint so I,ll keep in touch and let you know what goes wrong next week!! PS Don’t buy another hotpoint, we won’t.
    Thanks for this post.
    I did everything to the letter in your post and would you believe it, that was the problem and It took 45mins to sort out.
    It was a wire out of my wifes bra that jammed the impeller.
    And yes those plastic clips are hard to remove.
    Thanks again.
    #131186
    lulupsychob
    hi we had same problem followed your instructions it worked and we did it in 15 mins
    #131187
    helo_75
    i do it in five
    lol
    #131188
    ABEL
    pressure switch jammed on full. If you go onto Hotpoint web site you can print off copy of hotpoint error codes
    #131189
    helo_75
    8 mths ago
    do people ever read dates anymore?
    #131190
    frenchhurst
    Yes, me …
    My washing machine is my best friend and your website is the onely one which give me all the details to save “her”.
    Thank’s you “she” feels better 45 min after
    Effectivly the pump was blocked
    #131191
    helo_75
    brilliant, well done
    #131192
    ripuk
    This worked for me too on the WD645 – I think this is the same model just in Silver.
    Turned out the filter in the black rubber pipe had a bunch of different things in it – a number of plastic shirt collarbones as well as a bunch of buttons.
    To top it off though, and what I think caused the error code – a bloody hair pin stuck in the pump! 🙂
    Thanks for the advice everyone, saved me a fortune.
