Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › f & p 708 stops and turns off during cycle
- This topic has 6 replies, 3 voices, and was last updated 19 years, 4 months ago by
goanna.
November 14, 2006 at 11:18 am #22534
goanna
ParticipantI have A F&P 708 it is stopping during the rinse cycle and won’t restart unless turned off at the wall for at least several minutes it will then some times stop again and may take serveral attempts to finish a load.
having gone to the diagnostic page from the right we have 32 / 16 and 8 lite starting from the left we have 4 / 8 and 16 lite can any body help tell me whats wronggoanna
November 15, 2006 at 1:28 am #195378Penguin45
ParticipantRe: f & p 708 stops and turns off during cycle
Confused………….. It’s binary right to left only. First thought is draining, second is cold valve. Have another look at the lights, please.
November 15, 2006 at 9:31 am #195379goanna
Hi Penguin,
Thanks for your reply. I’m sorry, I don’t understand “binary”. Below is a diagram of the lights as viewed when looking at the machine. Each ‘o’ represents a light with the lit ones in red. Just to confuse things, tonight we are getting a different combination so I’ll give you both.Yesterday:
o o o o o o o oToday:
o o o o o o o ogoanna
November 16, 2006 at 2:21 am #195380Penguin45
Oh boy, a couple of beauties…….
First one is 56. At it’s simplest, it’s overloading. However, syphoning (losing water/not maintaining level) can do this, as can a faulty Rotor Position Sensor. Worst case is the motor controller board playing up.
Second one is 44. This is pump related, it thinks there’s excessive water in the drum when it tries to spin.
So………… Start with the pump and check for blockages and restrictions. Ensure that the end of the hose is above the maximum possible water level in the machine, to prevent syphoning; or the machine sucking back. It’s a twist fit from underneath, so easy to get to.
Power off, of course.
Penguin45.November 16, 2006 at 6:21 am #195381bigsmokepiker
ModeratorRe: f & p 708 stops and turns off during cycle
From your intial post when you say it stops are you referring to no lights on washer?If this is the case more than likely the pump is overheating .(they have an internal overload) Power to Controller runs thru pump.
That can be the reason why machine will start up again after being switched off for a while (IE Pump cools Down )
Check to see how hot pump gets you may also see signs of rusting on Pump
Power OFF
November 16, 2006 at 9:45 am #195382goanna
Thanks both for your replies. It sounds like a combination of both these problems. We’ll proceed accordingly.
Keep up the great work.
goanna.
November 23, 2006 at 11:03 pm #195383goanna
Many thanks guys I replaced the pump and it now is runnug sweet. I think the overheating pump was the answer.
Have a Great xmas or what ever you like to have and a great new yearCheers
goanna
