F & P ED56 dryer won’t start
Home Forums Public Support Forums International Forums Australasian Appliance Forum F & P ED56 dryer won’t start
  • #36942
    twum_au
    This Fisher and Paykel ED56 dryer powers up, the usual light display and jingle but after selecting dryer settings and pressing “start/pause” the machine does not start.
    The machine has not done a lot of work so I don’t think the motor should be worn out.
    I read somewhere that the motor start capacitor on these models is poor???
    Any clues please?
    Tony
    #252885
    kiwireeferman
    Re: F & P ED56 dryer won’t start
    Can you hear a hum after pressing start/pause?
    If you can, then it’s the motor or capacitor.
    If there is a series of beeps when you press the start/pause switch, check that you have not broken the pin on the door that operates the door switch
    #252886
    twum_au
    The pin that operates the door switch looks OK and I tried starting with the door open and I got beeps after pressing start/pause so I guess this means all is well with the door switch.
    I’m not getting any unusual beeps with the door shut.
    No I can’t hear any humming but there is a VERY faint metallic clicking if I listen hard, almost like something is warming up and causing expansion creaks metal to metal if that makes sense to you.
    Do these dryers have a diagnostic mode like the F & P washers???
    Just a suggestion but this machine belongs to my elderly mother and could she have punched any buttons on this that could prevent normal operation??? I can see a button with a padlock symbol maybe a childproof lock??
    I have only tried to operate this on default settings and a few variations on default, didn’t want to get too creative as I don’t like complex modern appliances.
    Thanks for your suggestions,
    Tony
    #252887
    kiwireeferman
    Press and hold the padlock button until it beeps, maybe she has set the kiddie lock. Didn’t think to mention that as I thought it would be too obvious. LOL.
    Dryer Controllers dont give much trouble.
    #252888
    twum_au
    I fiddled with the kiddie lock button and if I was doing it right (mum lost the manual for this machine) it shows a red LED when activated so I don’t think that is the problem but it was worth a shout LOL.
    Do the F & P dryers have a diagnostic mode like the washing machines?, if so how do I get that happening?
    Cheers,
    Tony
