I’ve done the diag test thing on this. Held down wash temp/pressed power. Wait for it to beep twice. Then press spin till spin/slow LED lights up.
The long wash LED (I believe you read from right to left on the WM)??
And the LED beside the spin LED lights up
So would the fault code be 010000001?
If I’m reading the service manual right, that means
65. (01000001) Phase 5 – Pressure Transducer Out of Range Error
Refer to Fault code 66 for action.
66. (01000010) Phase 5 – Pressure Transducer Out of Range Error
The Motor Controller has received signals from the Pressure Transducer outside normal values.
Primary Source – Motor Controller Action – Replace Motor Controller
Does this sound right to you guys?
I can still use the washing machine, but once it finishes it beeps like 9 times. I have to turn it off at the wall to turn it off
