F & P GW603 Noise coming out of bottom!
Home Forums Public Support Forums International Forums Australasian Appliance Forum F & P GW603 Noise coming out of bottom!
  • #39394
    Kiwiboy
    G’day,
    From reading the forum two weeks ago I was able to diagnose a faulty RPS and replaced it. Thank You.
    Now I have a new fault, 00101000. Machine fills and goes into wash mode but when agitating sounds like a very loud hand coffee grinder. Have dismantled, checked stator and all is good. I am picking the main bearing may have collapsed and caused this fault?
    Any help would be gratefully appreciated.
    #262319
    bigsmokepiker
    Re: F & P GW603 Noise coming out of bottom!
    Fault code 40
    When doing a bowl check the module has indicated that the bowl has not engagaed correctly
    Areas to check are The Clutch & or pressure switch tube
    CHeck to see if Bowl is lifting up & down corretcly when bowl is empty
    Check pressure tube in the Control panel Area (Clear tube That fits onto motor conrtoller) remove Tube stick your ruby lips around it & give it A good blow Refit & check washer operation
    Noise can be from these problems
    But when you replaced RPS DID You notice any signs of leaking water
    Bearing noise would be fairly obvious
    Finally fault 40 can relate to pressure switch which is integrated into motor controller
