f & p iw 810 fault code 105
  • #33253
    zap200
    F & p iw 810 comes up fault code 105 i was wondering if someone could please help with this code.
    #238011
    Re: f & p iw 810 fault code 105
    You won’t like it………
    Pump, motor controller, display module or rotor position sensor. Any or all can be at fault. If you have had work done recently, it is possible that the motor controller is incompatible.
    Impossible one to diagnose remotely – time for pro help!
    bigsmokepiker
    What stage of the cycle was the machine at
    IE Was it Filling,washing,pumping out water Spinning?
    Simplest thing to check would be drain pump
    #238013
    zap200
    i put a new drian pump in and then it was trying to fill and wouldnt then say activating detergent then filling repetedly before coming up fault code 131 and didnt work i then turned off then on and sterted to sort of work then under the control panel it went bang.
    any help would be appreciated.
    thanks
