F & P MW059 00110101 water spurts and then stops
Home Forums Public Support Forums International Forums Australasian Appliance Forum F & P MW059 00110101 water spurts and then stops
  • #37415
    vintagefabrics
    Earlier today the machine was fine until it went to drain the top load – water would’nt drain on top, but would drain on medium and low loads. Hubby tried to fix it this evening and now it just powers up, lights on board come on but when we go to start a wash the water comes out, stops, then spurts out and stops a couple more times before the error lights come up and the machine beeps – even when the power is off on the board!
    It’s a F & P MW059AU with the code 00110101 – the last 0 sometimes flashes, too.
    Any assistance would be oh so greatly appreciated!
    #255035
    kiwireeferman
    Re: F & P MW059 00110101 water spurts and then stops
    Fault code 53. Rotor position sensor step fail.
    Check wiring, corrosion etc to RPS board.
    #255036
    vintagefabrics
    Thanks so much Kiwi (from a fellow Kiwi) – can you please let me know where the RPS board is and what it looks like. I’m great at fixing things but not finding things! Cheers!
    #255037
    Follow the red, blue and yellow wires into the motor.
    vintagefabrics
    Thanks Penguin – very much appreciated! Thank for putting in the time to reply – you guys must be very busy…
    We’ll see how we go 🙂
