F & P MW511 won’t turn on
  • #45781
    jarednz
    Hi there,
    Hoping you can help with this. I have a MW511 that was working ok until our main power board blew a fuse while it was in the middle of a cycle.
    Since then, the power board has been repaired and everything else is working fine but the washing machine appears to be dead – I’ve tried different power outlets but no lights, no life, nothing.
    I can’t really afford a repairman or a new machine so really hoping I can fix it myself – sorry but I’m a total newb when it comes to stuff like this, the more information anyone can give the better.
    Thank you in advance,
    Jared
    #286977
    bigsmokepiker
    Re: F & P MW511 won’t turn on
    I f no power at all can only relate to Motor Controller(Main PCB)
    Beware there are components that can cause MC to fail
    Main culprit is usually the Divertor Valve (Located under Washer near the Pump)
    #286978
    jophil29
    This problem is a fail of the Motor Controller board and is NOT a job for a handyman or even a neighborhood electrician. You really need to take the board to a trained electronic tech who specialises in F/P board repair, of purchase a refurb board..
