F & P Smart Drive 601
  • #27316
    juss
    When I turn on my washing machine it just goes clunk, clunk, then starts beeping.
    error code: 00010000
    When I did a diagnosis test, it came up with: 00001000
    I am at a state of confusion, because I am now not sure if I have even done the right test.
    What i did was:
    Held water temp down button, with the power button.
    Pushed the advance button once.
    Pushed spin speed up button.
    It now reads High + Low LED on
    Spin Speed Hold on
    Top panel = 00000010
    Can you tell me if I am doing this right or what?
    #213527
    juss
    Re: F & P Smart Drive 601
    I forgot to mention that the SPIN SPEED is on:
    SLOW + HOLD
    Top panel reads 10000011 L-R
    #213528
    juss
    I think that adds up to 131
    #213529
    juss
    Ok, the more I read on, the more I realise how much infor I have left out.
    I hope this helps in resolving my problem with my washing machine
    Spin Speed Codes Water Level
    Hold 00000100 High + Low
    Slow 00000010 High + Low
    Slow + Hold 10000011 High + Low
    Medium 00100000 High + Low
    Medium + Hold 11101100 High + Low
    Medium + Slow 00100001 High + Low
    Medium + Slow + Hold 00111111 High + Low
    Fast 00100011 High + Low
    Fast + Hold 11101100 High + Low
    Fast + Slow 00100001 High + Low
    Fast + Slow + Hold 11111111 High + Low
    Fast + Medium 00000000 High + Low
    Fast + Medium + Hold 00000000 High + Low
    Fast + Medium + Slow 00010001 High + Low
    Fast + Medium + Slow + Hold 00001011 High + Low
    #213530
    Eeek!
    Clunk, clunk – motor kicking in. 10000010/1 – problems with the rotor position sensor (RPS) readings at the computer. RPS suffers from dampness, dodgy wiring, chaffing of wiring where it turns under the drum, corrosion or just plain failure.
    Let’s not worry bout the rest of it yet………..
    juss
    Thanks Pengquin for your reply.
    I could not help but laff at “Lets not worry about the rest”.
    So I would have to replace the rotor sensor…yes? and what would be the product code for that?
    That way I can order the part. Oh and would you recommend that I fix it myself, or get someone qualified to fix the problem?
    Cheerz
    #213532
    RPS is p/no 425221P.
    I wouldn’t rush off and buy one without checking first – throwing parts at something is an expensive way of repairing the machine, and I gather that components are not cheap for these machines.
    If you’re really not sure how to proceed, pro help may well be your best course of action.
    juss
    Hi Penguin,
    I did a search for that product code here in NZ, and the part has been Superseded By: 420296P – SD ROTOR POSN SENS MK2 SVC
    for $55.13 inc gst
    Does that sound like a reasonable price to you?
    I doubt that I would have a choice with that price range really…hahaha
    #213534
    I hate to say this, Juss, but I’m 14,000 miles away in Yorkshire – I’m afraid I simply wouldn’t know a good price for the parts!
    Anyway, at least check the state of the wiring down at the bottom first.
    Cheers,
    juss
    Will do and thanks for the help, I will keep you updated.
