F & P Smartdrive 058 Issues
  • #22111
    a.rolls
    Hi There,
    I have a F&P 058 that I have had to replace the coldwater inlet unit and ever since I have done that the water goes on and off in a surge for as long as I let it. I have used the setting info on this site to let it know it is a 5.5kg machine but it still fills up as much as it likes. The machine does not start no matter what level/temp/wash I have set.
    I then tried to put it onto spin mode to get rid of all the water-it started to punp out and then froze and started to beep. Lights were 0000I0II. Any clues as to what I should do please or do I need to call a service man.
    Andrew
    #193702
    Re: F & P Smartdrive 058 Issues
    Problem with the water level control. Drain machine fully and check that the air hose is not nipped, trapped or kinked. If all is OK, the problem may well be the pressure switch itself. This is integral with the motor controller board and must be replaced as an assembly.
    HTH,
    a.rolls
    Thank you for that I will give it a shot-how do you check for kinks please as I was able to blow through the hose and heard it bubbling-if the module needs replacement I assume that this is an expensive item.
    #193704
    bigsmokepiker
    When you checked pressure did you make sure that you pumped all the water out. Pressure tube runs from motor controller down to outer bowl
    Motor controller Part # 426204P $220.00aud
