F & P SmartDrive 500 GW500B-K
Home Forums Public Support Forums International Forums Australasian Appliance Forum F & P SmartDrive 500 GW500B-K
  • #19943
    Boldy
    Hi all, I have an F&P smartdrive 500, model number GW500B-K. As far as I could gather from this forum I pulled a diagnostic code by holding wash temp down and pressing the power button. After a second or so, the top 8 LEDs, from right to left, starting from spin, read 00100100.
    Not to sure on the failure mode, apparently when my girlfriend was using it, she started a normal wash, but then after some indefinite time it reverted to a different wash cycle and started beeping.
    Appreciate any replies, here or to mike_bold at hotmail dot com.
    Mike
    #185129
    bigsmokepiker
    Re: F & P SmartDrive 500 GW500B-K
    Fault code indicates water loss(Leak)
    IE The motor controller has needed to top up water level more than 4 times.
    Cause can been from siphoning Check drain hose height
    Other cause /check for leaks underneath washer around pump& shaft area
    In some cases it may be faulty motor controller (Main PCB)
    #185130
    Boldy
    Thanks for the information. Haven’t noticed any water on the floor or anything and I’m pretty sure its not siphoning. Faulty motor controller. Sounds omnious!
    #185131
    End of drain hose must be above the highest possible water level in the drum, creating an air gap. Possible that there is a pin hole in the air hose to the water level sensor – ensure machine is fully drained if you remove it to check.
    Boldy
    ok now that I’ve got home and checked, the drain hose is ok. I put a empty load on, it filled up ok, but didn’t drain completely and doesn’t spin.
    Holding wash temp down and pressing pwr button results in firstly the wash level low light on plus 00100100. If I press the advance button it changes to the wash level high + low lights on plus 00010000. What does this mean?
    Also where abouts is the drain valve located?
    Thanks for your help guys,
    Mike
    #185133
    bigsmokepiker
    00010000 Indicates Display/Motor controller out of sequence
    Turn washer off at wall and on again after 10orso sec
    Restart washer
    If fault appears again have disable restart feature
    Enter diagnostics washtempdown/power Use water level down button to turn restart on/off
    Low water level indicator off=restart off
    Low ”” ”’ ”” on=restart on
    Retest a new fault code should come up
    Note washer will not spin until water pumped out
    Pump is under washer bowl Power off if you fidddle with this
    #185134
    Boldy
    Thanks for the info. One step at a time, how do I empty the machine of water? I take it there is an easy way rather than bucket or siphon the remaining water? Must be some sort of drain valve or something?
    #185135
    No such luck 😀 . Hose in the bucket as low as it will go will get rid of all of it eventually. Or, use diagnostics to run pump only – Hold wash temp “down” and the “power”. Press “regular cycle” to run drain pump only.
    Boldy
    riiiiight got the water out ok, took the pressure switch tube off and blew threw it. This seemed to clear a little water out, so I tried another empty wash. This time the water drained, and the machine spun up ok.
    I’m still getting a couple fault codes however. The first one has changed to 00000100, and the other one is 00010000.
    Also noticed that the drain tube does infact have a hole in it, and it was likely that this had a small leak inside the machine.
    Can someone diagnose the first fault code for me? Thanks again
    Mike
    #185137
    bigsmokepiker
    OK Bad news
    Ist Fault code 00000100 communication error
    Motor control fault
    Can try turning on/off at wall but if faults again
    Likely source motor controller
    00010000 Display/motor controller out of sequence
    Look if it needs motor controller for this older model scrap him
    #185138
    Boldy
    oh dear looks like I’ll be breaking out mr visa 😕 Thanks for your help guys
    #185139
    Boldy
    Re: F & P SmartDrive 500 GW500B-K, found donor machine
    Hi y’all. I’ve managed to find a faulty machine, the same model as mine, that I was hoping to get some parts off. The failure mode on this machine is that it won’t spin. Pulling diagnostics from it I found a 00100100 (water level low light) and a 00000010 (water level low + high light). Possible that I might be able to get a control module from this?
    #185140
    bigsmokepiker
    Ist Code is pressure sensor fault
    Check that pressure tube is intact(Clear tube that connects to motor controller/then runs down to outer bowl
    This is your best case
    Other than that faulty motor controller
    2nd fault code indicates faulty display module
    Also is the washer just not spinning IE Does it fill ,wash advance Etc
    The machine will not spin until it pumps all the water
