F & P smartdrive 501 Washing Machine
Home Forums Public Support Forums International Forums Australasian Appliance Forum F & P smartdrive 501 Washing Machine
  • #13256
    chauscon
    Had an out of balance issue 2 months ago and now last night itj ust won’t power up at all. Tried changing power switches and no luck. Had the main board changed a few years back ,it was just 2 weeks out of warranty(typical) Where do I check now.
    #153820
    Re: F & P smartdrive 501 Washing Machine
    Do the obvious first – power coming in at all? After the power switch, it feeds through the display board, so that would be the next place to check – burnt/blown tracks etc.
    Awkward with guarantee just out – kick up a dust and see what you can get? A lot of manufacturers may be flexible or offer a discount towards further service, although we do have a few majors in the UK who absolutely won’t.
    Power off if circuit testing.
    chauscon
    Will power off or face the consequences.
    Not being a tech, do I just look for a small smouldering mess or black spots etc on the main board?
    Does this model have a cut out switch/overload at all?…just a thought.
    #153822
    chauscon
    Checked the display board and it looks brand new….not a mark…
    should I call out a tech …or not?
    #153823
    Hang fire for the moment – we’ve got a couple of repairers from down under who may be able to advise you further.
    chauscon
    Tks for that Penguin. Contacted F&P this morning …they want $99 to come out and look at the unit…that covers their labour and parts are a cost on top of that.I said I will bring the unit to you and I will put the replacement part in….its not that hard….no can’t do that. So will wait for advice from your members.
    Tks again
    Carl
    #153825
    FastAndPro
    Do you have a blue or yellow modules
    The yellow modules sometimes fail to fire up if the motor resistance is low should be 13 ohms
    Blue have a fuse if the fuse is gone replaceing it will only blow the other module they only go if the module has gone look for the tube leak at the end near the a mosfetts
    You cannot buy a new blue module for the 501 they are all rebuilt with 1 year or less G/T yellow modules are a kit pot luck new or rebuilt
    Check motor pump and bearings before you spend the big bucks
