Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F & P Smartdrive8 Diagnostic
- This topic has 4 replies, 3 voices, and was last updated 19 years, 2 months ago by
Jones.
January 15, 2007 at 9:44 am #24134
Jones
ParticipantThis issue seems to have been dealt with fairly extensively, however I’m still trying to ascertain what the hell all the codess mean. My washer simply will not operate after turning it on. All of the buttons provide the right visual display however nothing actually happens! So, what I’m really after is how dow do I interpret what the codes mean?
Thanx in advance,
Jones.
P.S.
Sorry, forgot the codes:01000001
10000110
00001100
00000001
00011101 (The last 2 flash between 01 and 10)
10011000
00001101
11111111
00000000 (last flashes between 0 and 1)
00100100
01000110
00010100
January 16, 2007 at 12:41 am #200812Penguin45
ParticipantRe: F & P Smartdrive8 Diagnostic
Sorry, Jones – haven’t a clue what you’ve been up to. First one is a pressure switch problem, second one is to do with the rotor position sensor, most of the rest don’t make sense.
Have you read and followed the sticky at the top of the forum? Not the one about the Ashes…..
Model number might be useful as well. I’ve asked BSP to have a look at this; he might be able to make more sense of it.
January 16, 2007 at 1:44 am #200813bigsmokepiker
ModeratorRe: F & P Smartdrive8 Diagnostic
Lets start from the beginning
Whats the model
Whats the machine Doing or not doing
Go to sticky as suggested by penguin & give us the last faultJanuary 16, 2007 at 7:40 am #200814Jones
Sorry;
-The model is GW708U
-As I said, when I turn the power on it gives me all the right indications as though it will work as normal. when ‘start’ is pressed, NOTHING happens, Oh I get the ‘beep’ and then that is it!
-Codes have changed a little since last post;00000000
00000000
00000000
01000001
10000110
00001100
00000001
00011001 (These 2 alternate)
0001100010011000
00001101
11111111
00000000
00100100
01000110
00010100
Thanks for your help so far, and ind in advance,
Jones.
January 16, 2007 at 10:36 pm #200815bigsmokepiker
You should only get one Fault Code?
But i would suggest from fault
IE Powers up But Nothing happens
Reed Switch problem (lid Switch)
Switch located under hob ,runs along RHS to rear control panel Area -
