F & P Smartdruve 058 solenoids repeatedly turning off an
Home Forums Public Support Forums International Forums Australasian Appliance Forum F & P Smartdruve 058 solenoids repeatedly turning off an
  • #19941
    MartyAJ
    Every three seconds the solenoids are turning off and on.
    The error code from right to left is 10001000.
    The only other light shown is ‘water level: low’
    #185124
    bigsmokepiker
    Re: F & P Smartdruve 058 solenoids repeatedly turning of
    fault code indicates motor stall error
    Possible causes
    Faulty motor controller(main PCB )Most probable
    Wiring harness break
    Seized bearings
    Or FaultyRPS(Rotor postion sensor)
    Check under washer for leaks If there are signs of leaking water
    then trouble
    IE Main seals /bearings main shaft RPS & possible motor controller(lots$$$)
