F03 Error codes on Bosch washing machine Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › F03 Error codes on Bosch washing machine This topic has 3 replies, 3 voices, and was last updated 19 years, 8 months ago by pistolpete66. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts August 1, 2006 at 3:44 pm #19599 pistolpete66Participant Hi, I frequently get F03 error flash up on my Bosch WFP series washing machine which usually means there is something in the pump filter. When I drain the water out and take a look, there is nothing there! Any ideas? Cheers, Pete August 1, 2006 at 4:19 pm #183774 MartinParticipant Re: F03 Error codes on Bosch washing machine It could also be associated with a restricted drain causing a ‘time-out’ error (F03)? Possibly a restriction in the drain hose or the drain coupling under the sink perhaps? August 1, 2006 at 6:36 pm #183775 ptoParticipant Re: F03 Error codes on Bosch washing machine could be the pump can be a bit intermitent being of the magnet type Jack August 2, 2006 at 11:28 am #183776 pistolpete66Participant Re: F03 Error codes on Bosch washing machine Thanks for reply – drain hose is clear, will check under the sink as it is a bit tight and I have dishwasher pipes there too. Hope it’s not the pump as that sounds pricey. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
