f03 lights 3&4 Ntc fault
  • #36686
    happycack
    Sorry to sound dumb on this but this indesit fault code refers to Ntc fault. What exactly is that?
    Ta.
    #251939
    Re: f03 lights 3&4 Ntc fault
    Temperature sensor – Negative Thermal (or Temperature) Coefficient – the hotter it gets, the lower the resitance. Usually gives a reading in kOhms at room temperature. Usual Indesit caveats apply – wiring and pcb are also suspects.
    Simon46
    The thermistor that changes resistance with an increase in temperature. Negative temperature coefficient. Model number would help.
    S.
    #251941
    happycack
    Indesit WIXXL 146 is the model if that makes any difference
    #251942
    Simon46
    :waving:
