F:11 Bosch WTE86304 (relay flashing on pcb)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries F:11 Bosch WTE86304 (relay flashing on pcb)
Viewing 1 post (of 1 total)
  • #87922
    gandh1
    10 year old, never been trouble. Started to cut out mid cycle, and then started F11’ing
    Cust called us out, noted that about 30 seconds into the timed 40 warm cycle it would stop turning and then youd see a green electrical flash from inside one of the relays before it F:11’d
    Send module to emw, they did a TD relay repair. Just been out to put it in and it would F;11 on any programme immediately. Wondered if it needed unlocking ala the washing machines so with a fiddle it seemed to unlock, and then did several start ups on the timed, refresh and sensor programs, and worked for over 5 mins on each.
    then i did something daft, i turned it off at the wall and unplugged so I could cable tied the leads back to the rear of the pcb and reassemble the machine but then it just comes up immediately with F11 if you turn it on and dont touch anything. Have tried to replicate unlocking it with no luck, however it did come up at one stage with P:07 when it was on the refresh position, wondered if that was part of diagnostics?
    Help please! customer is an impatient one. Any BSH Service manuals for these?
