F3 Fault
  • #75349
    kenwaugh
    We have Whirlpool diplomat ADP8332 Dishwasher.
    I opened door when I thought it finished but apparently not.
    Operation appeared to have finished , water had drained and everything was spotlessly clean.
    However machine had low hum for a while and then LED showed F3 fault.
    If machine is ok can you advise if I will be able to reset.
    #394632
    Re: F3 Fault
    You won’t be able to reset it.
    It is a failure on the heating circuit somewhere, usually the heating element which is this one but I obviously can’t guarantee that, you’d have to check it.
    The full meaning of the error code is here: http://www.ukwhitegoods.co.uk/help/faul … codes.html
