Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Fabric Softener Not Going Through
- This topic has 8 replies, 2 voices, and was last updated 18 years, 5 months ago by
kirkie.
October 21, 2007 at 9:11 am #31550
kirkie
ParticipantAny ideas why this wouldn’t work? I have taken the tray out and put water in it and it comes out so scratching my head…
October 21, 2007 at 9:23 am #231630Penguin45
ParticipantRe: Fabric Softener Not Going Through
This is the Samsung, yes?
If the syphon is working when you fill it manually, then logically it isn’t getting water when it’s in the machine. Check the holes in the roof of the soap box.
October 21, 2007 at 9:53 am #231631kirkie
Penguin45 wrote:This is the Samsung, yes?
Yes that is slimey and scummy as I don’t know what. What is the best way of cleaning that?
October 21, 2007 at 11:24 am #231632Penguin45
Toothbrush for scrubbing, skinny bit of bent wire for pricking out the holes.
October 21, 2007 at 11:30 am #231633kirkie
Penguin45 wrote:Toothbrush for scrubbing, skinny bit of bent wire for pricking out the holes.
The drawer itself is spotless, but it is the slot it fits into that needs cleaning. If I was to use a brush etc wouldn’t it fall and block tubes etc?
October 21, 2007 at 11:42 am #231634Penguin45
The soap drawer fits into the soap box.
Yes, all the muck and goo will fall off. You’ll be able to mop up most of it, but some will wash down inside. This is the point at which you perform a sevice wash:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=162
October 21, 2007 at 11:49 am #231635kirkie
Penguin45 wrote:The soap drawer fits into the soap box.
Brilliant I will have a go at that tomorrow on my day off. Thanks for all the advice….
October 23, 2007 at 10:03 am #231636kirkie
Yes that worked a treat….Thank you
January 28, 2009 at 7:11 pm #231637kirkie
ParticipantI am having this problem again and I have cleaned all of the holes. Any ideas please?
