Fagor dishwasher VFU-651T stat required
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Fagor dishwasher VFU-651T stat required
  • #12813
    bobokines
    Mod VFU-651T
    COD 906470991
    TYPE DW-24E1
    NIF ESF20020517
    SER NO 010621733
    Hi.
    Anyone able to help with a part number for a safety stat for the above dishwasher. It has no maker’s name but it is obviously a Fagor
    Thanks in advance
    Bob
    #151710
    Dave_Conway
    Re: Fagor dishwasher VFU-651T stat required
    I can’t see a seperate stat Bob, if it’s on the heater tube then it’s the whole heater, part number V12B000A9.
    There are two NTC’s inside the door, both part number V75A000Y0
    #151711
    BobHope
    Hi Bob
    is this thermostat located at the lefthand side abt 6 inchs back and held in place with a spring clip.
    Bob.
    #151712
    bobokines
    Hi Bob
    That’s the one, it’s two pole and in series with the heater.
    Bob
    #151713
    hi bob
    the part number you need is V75A000G2 83oc safety stat
    in stock or AIS
    bryan
    #151714
    bobokines
    Sorry Bryan, what’s AIS?
    When you say in stock do you mean that you supply spares?
    Bob
    #151715
    hi bob
    yes i can supplythis part if you required
    bryan
    #151716
    bobokines
    Thanks Bryan. PM on way.
    Bob
    #151717
    BobHope
    hi bob
    this thermostat is resetable carfully remove the top cover and reset the thermal trip and avise the customer about restictions to the lower spray arm as that is what causes the problem in the first place
    Cheers Bob.
    #151718
    bobokines
    Bob
    #151719
    bobokines
    The appliance is as new. It was installed two years ago but never used. The machine had a wiring fault from new.. The plug on the fill level microswitch was upside down! It had obviously not been tested at the factory.
    I felt quite proud of myself to be able to find the fault without ever having seen this machine before and with no chances of a wiring diagram.
    This was a few months ago and the flat has now been let and the machine is now being used. After only two weeks the overtemp stat has cut out.
    The landlord is happy to pay whatever it costs to do the job properly so I would prefer to fit a new stat rather than reset the old one. Just in case it’s out of calibration.
    I will let you know the outcome.
    Bob
    #151720
    BobHope
    diagrams and info is available if you need it bob just ask or pm your email
    Bob
    #151721
    Tom
    ❓ I have one of these dishwashers which takes in water & circulates for a few minutes then puimps out and flashes No 2 led alternately with No 1, 3 & 4 together (counting from the left.
    This is not listed in the known fault codes.
    There is not heating action although the element tests OK. Will check the thermostat as suggested (resetting).
    Also need the steel band which connects door to door spring if any one has P/No or stock
    Thanks for any help
    tom
    #151722
    Dave_Conway
    Steel band part number is VF6B00C3 🙂
    The error codes are in the known ones at the top of this forum 😉
