fagor firdge freezer
  • #59101
    DDSDDS
    hello i have a
    1 FFC 36 LAX UK
    when plugged in it runs fines but today ambient temperature is 20deg but inside fridge is 30 deg
    there is a fan inside a plastic housing now this fan has been switched on the entire time and has become slightly warm could this be the cause of the temp rise if so what is the fan for is it a fast fridge option or….
    if not any ideas
    thanks
    danny
    #336817
    ben–nevis
    Re: fagor firdge freezer
    The fan is purely to improve the air flow inside the unit and keep a more even temperature. there is a defrost heater in the back wall which could be on continuously, could also be the door switch leaving the lamp on. I assume the system is ok?
    if you let me have a contact email I will send a wiring diagram if this helps.
    Hope this helps
