Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Fagor FU-6116IT help
- This topic has 4 replies, 2 voices, and was last updated 13 years, 8 months ago by
will_08.
August 27, 2012 at 2:23 pm #71166
will_08
ParticipantHello 1st post on the forum! 😀
Was after some advice regarding the washing machine above, for ages now it ends the cycle with “F06” error.
Ive found on here it means?
Water heating error detected – Failed to heat for 15 minutes
Check wiring to wash heater and thermostats
Check wash heater for continuity
Check NTC (temperature sensor) probeIve measured the element at 30 odd ohms this seems high to me?
Also during the cycle it makes an unusual noise, i dont think its the motor. its like a “groaning” (like something is being impeded!) and i think its happening on draining. ive removed the drain motor and its free (connected it up to an external power source and it operates fine.
Is there a solenoid valve or something that feeds the water to the motor?
Your help would be much appreciated
Cheers Will
August 27, 2012 at 3:12 pm #380214kwatt
KeymasterRe: Fagor FU-6116IT help
If you’ve got continuity on the element it should be okay but, check the thermostats or thermistor as well.
As to the noise, could be anything you’d need to try to narrow it down a bit.
August 27, 2012 at 4:41 pm #380215will_08
ParticipantRe: Fagor FU-6116IT help
Thanks for the reply
I think i may have cracked the heater fault, i noticed there was power to the temp switch but not after it. When i removed it there was a little ‘switch’ holding the contacts open. ive reset it and now have mains on the element and a hot glass on the drum door 😀
as for the groaning i noticed there were signs of sand around the drain motor assembly.
Maybe sand has got in there an intermittently causing this noise, it does seem to happen sometimes during draining.
Thanks Will
August 27, 2012 at 4:43 pm #380216kwatt
Yup, sand in the drain pump will do that if it gets in between the magnet and casing.
August 27, 2012 at 5:31 pm #380217will_08
Your bob on K.
the F06 has gone, but still the horrible noise.
Whilst it was happening i dropped the neutral off to the motor and it instantly stopped.
Thanks for you input, smashing forum btw, i’ll be sure to keep dropping by in the future
Will
