Fagor FUS-3611IT no drain pump on dryer cycle?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Fagor FUS-3611IT no drain pump on dryer cycle?
  • #52054
    Simon46
    Machine spins and drains ok. However on dryer cycle cannot hear drain pump running. Put to spin drain pump operates. Even filled machine with water thru soap dispenser whilst dryer running did not kick in. Is it a timed pump cycle or does it run off pressure switch?
    Does anybody know what may cause this?
    Regards
    S.
    #310457
    Simon46
    Re: Fagor FUS-3611IT no drain pump on dryer cycle?
    Or does anyone have a circuit diagram?
    S.
    #310458
    Simon46
    Goin for power board as pot luck on this one. :con:
    S.
    #310459
    Simon46
    Repalced PCB Still the same. Inlet valve solenoid no supply to as well. 😕
    Metered heaters etc.
    S.
    #310460
    Simon46
    Got to return to this one. Anybody got any ideas?
    S.
    #310461
    How long have you left it before deciding its not coming on? Pretty sure I had one of these and it was like 15 minutes before valve and pump are energised.
    #310462
    Simon46
    Quite a while. cust complains does not dry.
    Many thanks for the info 😉 that person who sent it.
    S.
    #310463
    Allsorts
    are you sure the dryer heater is working? Would failure of this cause the pump not to run?
    George
    #310464
    Simon46
    Right me and roly16 attended fitted new pcb again. Started 95 min dryer cycle and at 80 mins pump and valve kick in. Sorted. Many thanks eastlmark:-
    S.
