fagor IFF-4R induction hob
  • #67826
    robedoo
    going to this one on monday two rings not working had a similar problem with an aeg recently and had too replace the board this one appers to have 2 boards but i’m inclined to think the keyboard is the most likely anyone else come across this?
    #368708
    Lawrence
    Re: fagor IFF-4R induction hob
    pm
    Ben Nevis he’s 8) on fagor stuff
    #368709
    robedoo wrote:going to this one on monday two rings not working had a similar problem with an aeg recently and had too replace the board this one appers to have 2 boards but i’m inclined to think the keyboard is the most likely anyone else come across this?
    you will probably find the rings and boards are in pairs, hence one failure of the board will effect 2 rings. If you are lucky it may be a terminal block issue….If the board is blown then chage the corrosponding ring as well otherwise the new board may go bang again.
    Just had a Miele induction hob with just a single board for all 4 rings. £750+ vat for the part!
    #368710
    johnmac11
    Try ordering the rings for the Whirlpool induction hob, all four come as one unit and cost £1114.14 ex vat from CDSL, the boards cost extra :eeek:
    John
