Fagor oven timer cutting out
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Fagor oven timer cutting out
  • #79139
    simtoms
    Morning folks,
    I’ve been looking at a Fagor 7H-750X3 pyrolytic oven which has a fault with the timer cutting out after a few minutes operation. You can reset the timer and it cuts in but again only for a short time. I don’t think it’s a thermal issue as it doesn’t run long enough to get very hot. It seems like the timer goes slightly faint when you try and run the oven.
    I thought probably new timer but does anyone else remember having this and what the cause was?
    Many thanks,
    Simon
    #408131
    twicknix
    Re: Fagor oven timer cutting out
    My experience with Fagor oven especially pyrolitic types are hit n miss. Sounds like board relay and it’s costly to replace. Check for relays on the board, usually they are semi transparent, if you see black marking then you have the culprit. I think there are 4 relays.
    I think I still have the new board somewhere. Don’t know if this would fit this model.
