I have FAGOR Select FE 536 washing machine. More than 10 years old. I would like to buy SIEMENS heat pump tumble dryer and place it on top of the washing machine. Can I do that safely? How much weight can this specific washing machine bear? Do I need a stacking kit and if yes from which manufacturer and model?
Re: Fagor SELECT FE 536 washing machine – weight it can bear
“Hi
The washing machine will taken the weight but I would stand the dryer on a piece of thick carpet so it has less chance to move. You will also need to find someway of securing the two appliances together.
There are universal stack kits available but you may have to “adapt” it to fit the two different shapes of cabinet.
