(Fagor) type D/Washer Sarena SW200 wash pump runs permenatly
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries (Fagor) type D/Washer Sarena SW200 wash pump runs permenatly
Viewing 1 post (of 1 total)
  • #27120
    TELL
    Been out to dishwasher, model as above, for a jammed door latch. Customer could not close door as latch locked in ON, position.
    fitted new latch and plate, door can be opened/closed ok. test on quick rinse. m/c filled, washed, and drained at end of programme. BUT the Wash pump continued to run, and would not shut down at the end of the programme. you can select another prog, set it away, and it does the same thing at the end. the motor is getting a permenant feed of 240v. the only thing i can trace it to, is the control module??. OR has somebody else have any suggestions.
    the module is V54E000F4 on masterparts site. expensive if wrong.
    TELL..
    P.S. there is no fault codes coming up on panel,
    PPS. is there a reset procedure for this model aswell??. if so can you advise me on the sequence.
