Fagor will not empty!
  • #67871
    ChrisWren
    We have a Fagor FT 3117 washing machine that keeps giving error d06. It is 6 months old. There is no blockage and nothing appears wrong with anything. This error code is common but does not happen every time.
    How to resolve please?
    Re: Fagor will not empty!
    Are you perhaps using a little too much soap and the foam is holding the pressure switch open thereby fooling the machine into thinking it hasn’t drained?
    Very common problem these days.
    ChrisWren
    kwatt wrote:Are you perhaps using a little too much soap and the foam is holding the pressure switch open thereby fooling the machine into thinking it hasn’t drained?
    That is interesting, thanks. Will try and investigate this!
