common fault is the door switch, behind the panel under the doors – falcon are up here at larbert in scotland – near falkirk – but spares available from various outlets few around manchester.
hope this helps, eddie
try also rangemaster…they have a tie-in with falcon….most have same chassis / electrics…falcon designed to look a bit more commercial with a few extra gadgets.????
fan element common prob…can be done from front…only prob can be re-attaching earth wire to new element…
if you need to remove cooker pull out storage drawer locate jacking point @ left…jack up with molegrips etc..and ckr should pull froward ??
