Falvel Milano 100
  • #89721
    livy
    Hi, i’m in the process of looking to fix my Girlfriends mums range cooker.
    its a duel fuel flavel Milano ML10FRS.
    The fan oven went a while ago and have been using the other cavity which has now gone,
    The indicator light comes on and the fan comes on, however no heat comes out at all.
    I’m trying to fix the fan cavity first. quick look seems as though it could be the element,
    is there anything else that could cause it, eg safety cut out or thermostat.
    its akward to remove the appliance and not a lot of room to work in so would rather be prepared before starting the job as the element is fixed from the rear.
    any help would be great.
    #442302
    Re: Falvel Milano 100
    if the temp light comes on its most Ilkley the element
    livy
    Cheers. I think I’ll get the part ordered. And get them to have the cooker out for my next visit. Cheers.
    #442304
    https://shop.ukwhitegoods.co.uk/4629000 … en-element
    this is the gen element for your cooker. i find the copy units are not as good these days so its worth paying a bit extra
    the screws holding the element go in from the rear of the cooker so as you say you will need it pulled out
