Fan in Blomberg double oven not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Fan in Blomberg double oven not working
  • #57581
    Bea
    Hi can anyone help – mother-in-law has Blomberg EOD 605B double oven. Fan/heat in main oven not working although if using correct dial setting the upper and lower elements do heat the oven. Any suggestions as to whether I need new fan element, fan oven motor and blade, or just the fan motor. Any help appreciated. Bea
    #331655
    Jackal
    Re: Fan in Blomberg double oven not working
    Sorry there is not enough information to assist really.
    Does the fan motor run when the main oven is selected?
    In its very recent history, has the unit blown the electrics or trip in the house?
    Is there any heat at all (even if only a small amount) when the main oven is selected?
    Answering the above will assist in trying to identify the problem.
    If you are going to work on the appliance yourself, please remember safety first and disconnect it from the mains supply.
    Regards
    Jackal
