fan motor not working properly
Home Forums Public Support Forums Help And Support Cooker And Oven Forum fan motor not working properly
  • #103582
    giveitago616
    Hi all. Fan isnt turning in the main oven. I took the inner back plate off, loosened the fan blade, tightened it back on, it turns for a few minutes, noisily, then gives up! I’m looking for a motor to buy online, but not sure about the oven model. Its a beko kd533a, but i can only find parts for kd533ak and kd533as, so not sure of the difference! if it helps at all, the serial number on the motor is, i think (4)210621 though its a bit faded so not sure about the (4).
    Ive found a motor on espares that looks the same, though the the contacts for the blue and yellow wires appear to be in a different place, wanted to check if this model would be okay? or if anyone can direct me to a site to buy, then thats great!
    #493808
    ok cant be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain without serial no and commercial code off label but there are 3 cookers with model numbers starting KD533A
    they all use the same fan motor but as said can never be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} without an accurate serial no
    fan motor part no 264440193
    giveitago616
    electrofix wrote: ok cant be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain without serial no and commercial code off label but there are 3 cookers with model numbers starting KD533A
    Brill, thanks for the quick reply. just found the full model code off the bottom front of the oven, it ends in a k, so its kd533ak
    #493810
    well motor number is the same as i check all the models but
    sometimes Beko change part numbers half way through a production run. the only way we know is when we enter the serial no and the part number changes. unlikely but possible
