Fan Oven Element
  • #19618
    Maloney
    I’m having a problem locating a 2100w fan oven element for a
    Nardi mod. FEA 0614.
    Stamped on the element is the load rating as above
    and 04-4593 Corel – 5 – 04.
    The fixing holes are 4mm at 56mm spacing.
    The distance between the 70mm x 22mm fixing plate and the outer of the element is 215mm. It has 2 turns
    Qualtex my spares supplier reckon the cooker is manufactured with a veiw of any supplier using their own brand name on it. IE Nardi could be one of many.
    A local company Kwikcook appear to have a similar modified version with 3 turns and is 2400w but they are on holiday shutdown.
    regards Maloney
    #183857
    Simon46
    Re: Fan Oven Element
    Fitted a ELE2015 to a FE0614 recently. Perfect fit 3 turn. Hope this helps.
    http://www.ukwhitegoods.co.uk/modules.p … t=fea+0614
    S.
    #183858
    Maloney
    thanks for the prompt reply Simon.
    I am taking your advice and have already located the part and diagram of the dimensions
    regards Maloney
